you need to enable the function “ shoot without a lens"
Might sound counterintuitive but it means shooting without an autofocus lens with a chip.
Third party lenses ( aside from Zeiss) wouldn’t work too.
Go to the last option at the bottom of menu 3.
Good luck!
My pleasure, anyway it is all in the manual recently re-released.
Good luck!
Thanks a bunch !
