HAVE YOU EVER WANTED A BLUETOOTH REMOTE TRIGGER FOR YOUR FUJIFILM?
I did and could not find one anywhere!
PS I'm not selling anything
I did not want to use my phone as I shoot in precarious spots and did not want to risk injury and loss of phone at the same time and tbh I like to take time away from my phone when immersed in photography
I did not want a cable release either as its a faff and a risk to pull tripod over by accident imo
I also did not want a remote with a transmitter added to the camera because its more stuff to setup and take and more places for water to get in
I managed to eventually get this sorted after much hassle and thought I'd share.
I am NOT selling anything and all youll need to buy is the transmitter and follow the step by step instructions
I was contemplating having this brought to market but tbh fuji could just bring one to market in days and at half the cost I ever could.
Why give away my little limited edition secret? Well why not? I may get a coffee bought for my hard work but tbh I just felt like sharing something that has made my fuji life better
Anyway I hope that helps anyone out
Adrian
My blog explains what to do
https://www.thenowherephotographer.com/blog/fujifilmwirelessbluetoothremote
