I recently had my X100F serviced (after 5+ years of great use) and while I’ve managed to get most of my preferred settings back to usual, I’ve run into an issue with the exposure compensation dial.
I can no longer see the impact of exposure compensation dial adjustments through the viewfinder. I can see them on the LED screen and in the final photos, but not when I have my eye to the viewfinder. I definitely used to be able to and am stumped on what needs to be adjusted.
I use the exposure compensation dial a lot so it’s proving very frustrating not to be able to adjust it while using the viewfinder!
Any ideas on why this may be happening or what settings I may have missed?
