Can anyone recommend a CFexpress card for the Fuji X-H2S? I plan to do mainly wildlife shooting with some video. I will probably stick with 4K video. I'd like a fast card though for burst shooting and fast buffer clearing. I only need 150 Gigabytes or so and don't want to break the bank. Thanks for your suggestions in advance!!
1 hour ago, pjtmac said:
Thanks Greybeard. I'm in Canada and can't track this one down on the Amazon.ca site.
This is the card I got - it’s not available from Amazon in the UK either - I got it from a camera store (in the UK)
https://www.vistek.ca/store/451271/150GB-BLACK-CFexpress-Type-B-Card-1725MBs-read-&-1530-MBs-write-speeds
its my only CF Express card so I don’t have anything else to compare
