Unfortunately my X100V took a fall on the asphalt by which the topplate has bent on the side. Now there's a gap at the side so I had to send out to repair to Germany. (I live in The Netherlands)
I had it send out on 20th of may and the people in the store told me it would be two weeks that I would hear about the repair-costs. I haven't heard anything yet. I was just wondering if any you  have experience with fuji repair service in Germany. How long did it take for you?
thanks.
Edited by J.A.
    • The backslashes you are referring are just symbols denoting path.  Once you import into these LUTS into Davinci Resolve those backslashes are removed by default and you only see is the true file name which has no backslashes.  Convince yourself of this by opening the LUT folder from the Davinci Resolve Project Settings.  Do you see any backslashes in those LUT names? Of course not.  The only name you see is the one that has the underscores and the periods. These LUTS work as designed without having to change any path names.  However, they need to be set up properly set up through CSTs and by what is supported in Davinci Resolve.  Hence, the FLog2C LUTS cannot be used because Davinci Resolve does not support Fuji Gamut color space and the FLog2C gamut. Alternatively, Davinci Resolve does support Flog2 because the color space for FLog2 is Rec 2020 and there is an FLog2 gamut. If all you are doing is changing the path names then most likely you are not getting the correct results.
