Hello,
I am writing to you because I have a problem.
While changing my lens I just realized that my mirror had a mark which is not visible when I use a small focal length.
Do you think it can be cleaned?
I am really sad because my XT4 is new and I don't understand how this could happen.
Thank you for your help.
Théa
