US based, Do I need a converter to charge in Europe?
Hi there brilliant people,
I'll be in France and Italy most of May. Prior trips were short enough not to require charging in Europe. I expect I'll need to charge on this trip
I cannot find conclusive information whether I need a converter or just an adapter for the EU plugs. Anyone know or can point me to the right information?
Thanks!
