I've searched the Forum for this issue and haven't been able to find anything.
When playing back images on the X100T's LCD, they appear as over-exposed, even though they're perfectly exposed.
When viewing the same images through the viewfinder they appear normal and as exposed.
I've noticed this from the outset when I bought the camera last year.
It's more an irritant than anything else.
Is this a known issue or an issue anyone else has encountered?
Any feedback would be appreciated.
Thanks,
