Hi !
I went to one of the local ski center last Saturday with my X-T1 and XF50-140 + XF1.4TC combo to shoot some university level FIS sanction Slalom race (they are fast!).  There was also a Free Style event on the slope right by the slalom course so I was able to get a few SIF ( Skiers In Flight) pics as well.
The Flickr Album: https://flic.kr/s/aHsks7x5WG
The Fuji-X Sport and Action Group on Flickr:  https://flic.kr/g/quLzW
Thanks for looking
Gilles
These are very good. What focusing mode did you use? I am still undecided between zone and single point focus for this kind of pictures.
Thanks ! For these I used de Zone mode , 3x3 grid for the Free Style and a mix of 5x3 and 3x3 grids for the Slalom
Thanks for the fine sports pictures, Gilles.
Wide Tracking + C + CL - that's it in my opinion!
Regards Rieke
Hi ! Thanks too ! Wide Tracking will use the outer (and slower) CDAF points on the sensor, it is better to stick to the central hybrid CDAF/PDAF points for fast subject, either with Zone or Single
Here are the settings on my X-T1 when I'm shooting sports
High Performance Mode is On,
Pre AF is On,
AF-Mode mostly on Zone, 5x3 grid or 3x3, and only the central PDAF points are used, I'll use Single Point if the subject is a busy pack of athletes to keep the AF from jumping from one to the other.
Release /Focus Priority is set to Focus (both for Af-S and Af-C),
Face detection = Off
Eye detection = Off
Shutter on MS only.
AF is on Continuous and the Drive Mode is on CH (8fps),
My EVF is set to Normal, not Full
LMO is On (even if I'm shooting RAW only)
I'm shooting RAW only with a 300mb/sec 64gb SD UHS II, no problems with the buffer.
I usually aim and half-press the shutter while tracking the subject, I'll then fire a short burst when the subject is close to the optimum distance.
The hard part is aiming during the black out, practice and anticipation is the key, but I'm sure I'm going to love the X-T2  :)
Thanks again
Gilles
    • It's that time of the year alright.
    • I got my X-H2S back from Fujifilm Canada, where I sent it in due to a firmware-related issue. They "repaired" it at no charge, which I appreciated — but now it's come back with a completely new issue and is basically unusable. As soon as I attach any lens, the screen starts blinking for about a minute, then shows a “Lens Error” message. I’ve tested it with three different lenses, with and without a memory card, and the result is always the same. The problem only goes away when no lens is attached. This issue didn’t exist before the repair. It was returned to me marked as fixed, but now it’s even worse — I can’t use the camera at all.  Video showing the issue: https://youtu.be/ki7oHViDwsQ
    • I've been using an X-T3 for years... Now I just decided to give an X-T50 a try, mainly for IBIS and supposedly better autofocus... As light goes down it is much worst, I started to notice it immediately! I tried with bot the 27mm 2.8 and the 35 1.4, I know not the best lenses for autofocus, but still the X-T3 handles it much quicker in difficult/dark situations, Here is a video, the first is the X-T3, the second the X-T50: https://www.dropbox.com/scl/fi/14mxqd5xkltwz609x3s52/test-focus.mp4?rlkey=xsc6v5zzke2n4m9q4x2wldoci&dl=0 Tracking is even worst!!! : https://www.dropbox.com/scl/fi/9kejtzmlkidyauymh53nk/test-focus2.mp4?rlkey=axg3j51c4nknwgz4ewf9obuj2&dl=0 Both camera same exact settings, both on latest firmware and both in boost mode
