Luminar Ai How das it processing Fuji Raw files
Hey guys. I need a better lens for my surf photography job and Was wondering which of these two lenses is better for that. The goal is to shoot from the beach so I think what’s important is the image quality of higher ranges. Am I right? Considering they’re both 300mm and the same price range, is the Fuji a better choice?
Welcome to our forum. Did you reformat the cards inside the camera?
By HannahB593 · Posted
Hi there, So I have a Fujifilm XT4- I have a read error that popped up maybe 4 days ago or so now. It's frustrating bc I can't shoot video on my camera. 5 seconds into shooting... the video stops and it says "Read Error". How do I fix this? I already reformatted the SD cards (both of them) like 2 times each. What gives? -
You need the appropriate LUT (cube) file for this to work. This is also possible with JPEG photos. Just not so accurate because the JPEG photo has only 24-bit resolution. (RAW = 42-bit).
I do not see a brightness button on the back in your image, but if it has a button whose emblem is a circle with a lot of lines popping out from it, Fujifilm usually uses that as a lcd brightness controller. Do you have the manual for the camera? If you have an external card reader, the video and images on the SD card can be copied over to your computer.
