DxO PureRAW 2: Now with Fuji X-Trans support!
Yes Is some small amount leftover from the spot i cleaned. Inside only very less point of dust,yes my be are from manufacture Is very microscopic. anyway on pictures i not see dust and i not see the spot i clean. thankyou so much for your reply Is beautiful im Happy.Have a good day
Are you certain the spot is on the inside and not some small amount leftover from the spot you cleaned? Maybe try a different brand of lens cleaner, but make sure it is safe for lenses so that the lens coatings are not removed. Even weather resistant lenses can get dust inside, the seals can only keep out so much dust and zoom lenses are known to get dusty on occasion. More so than prime lenses do. Weather resistant means more sealing, but achieving perfect sealing is tough to get. It is also possible the dust has been there from the time it was manufactured and you are only now noticing because of the white dot. Does the dust show up in any of your photos? As far as cleaning cost goes, your local camera repair shop will be able to give you some estimates, prices will be different depending on where you are.
Hello, After a long travel i see a micro white point on lent. I try with a product clean but not gone. After i try 50 time very gentle in many days. The micro point are gone but still a micro micro point. The lent Is 16/80 fuji. After if i look lent in the direct sun i can see some micro points of dust. Very less but the lent on paper Is water resistent. So how can have micro point of dust inside? Anyway how i can clean or where i can go for clean my camera and how much can costly? Thankyou everyone
Update: the camera seems to have self-corrected. 🤷♂️ My working hypothesis is that moisture caused it to glitch, and after drying out, it's working again.
