Hello-
In the process of writing an article about my love of the 50mm perspective, I've re-written and reposted this article, which originally was written for X100c.com. My forthcoming article will include comparison to the forthcoming XF 35mm f2, due to ship any day now...
http://www.bradleyhanson.com/blog/2015/11/4/fujifilm-tcl-x100-review
