why capture one export makes better jpeg output than iphone app with fuji XT4?
does anyone know why
FUJI-xt4 => iphone app transfer via bluetooth => iphone camara roll  quality is way less than quality
FUJI-XT4 => capture one direct import from sdcard => export jpeg files = end up with way better quality pictures
I dont see any setting on the app that compreses jpegs more or less
you help is apreciate it !!
thanks for your reply guys. yes just found out that on
SET UP -> CONNECTION SETTINGS -> GENERAL SETTINGS -> RESIZE IMAGE FOR SMART PHONE -> set to ON by default .. needs to be OFF to get full res images in iphone
to bad I loosed tons of images quality because I was in the idea that I had the "original" ones in my iphone and it was not the case..
FUJI should set OFF by default :S
