Have you set which option you want for the rear command dial in your setup menu? The choices for the dials are on page 207 in the full manual.
https://fujifilm-dsc.com/en/manual/x-t30/menu_setup/button-dial_setting/index.html
It sounds like you currently have the ‘none’ option set.
