I cannot for the life of me figure out how to adjust the aperture from the command dial. I have the lens aperture set to A and the command dial set to control the aperture, but it says "s" in the shooting mode and will not adjust the aperture from the command dial.
I am a life long canon shooter, so I'm used to just having a manual mode that allows me to use the command dials to adjust every function. Can anyone help me figure out how to get this xt-30 into manual?
