Hello, new member here
Just got off the phone with Fujifilm USA tech support desk, who confirms that using a remote shutter release cable is NOT an option for this camera, it wasn’t designed for that.
Major design flaw
  • 6 months later...
On 3/16/2021 at 12:47 PM, jerryy said:
I must have came in very late to this thread and obviously missed something.
http://fujifilm-dsc.com/en-int/manual/x-s10/about_this_camera/parts/
This clearly shows where to attach a remote release cable and explains how to adapt the standard Fujifilm remote release cable to work with the X-S10.
Specifically see item 22 in the diagram at the URL (or the camera diagram in the user manual). Remarkable that tech support would deny the existence of a feature.
  • 6 months later...
Just ran into the same issue, don't want to use my phone to trigger the camera. would rather have my eyes on the subject I am photographing!
Just bought the RR-100 on the recommendation from B&H, and also just ordered a 2.5 to 3.5 converter from Amazon, will report if it works. The first converter was a 4 pin and it did not work.
I use cable release often. I changed the setting for the microphone jack to remote shutter and bought a very cheap on Amazon cable release which had the matching connector. It seems the socket in other Fuji cameras is a different size so the Fuji remote won't fit X-S10, but mine works perfectly.
Simon.
Hi folks. Just purchased the Kiwi cable switch that replaces the Fuji RR-100, along with a 2.5 to 3.5 mm adapter for my X-S10. I changed the Mic/Remote release to remote, but it isn't working. I notice that the 3.5 mm end of the adapter doesn't completely insert to the housing, (see photo attached) but it did "click" into place (other connections seem secure.) Not sure what else to try. Suggestions?
    • I never knew the X70 existed! Looks interesting.
    • Equipment: Fujiflim X-M5 (firmware V 1.10). iPhone 15 pro (26.1) I am unable to properly connect my Fujifilm X-M5 to XApp on my iPhone 15 Pro. This setup previously worked without issues, but now the app only supports a basic remote shutter and no longer allows Get or Take mode, which are required for remote parameter control and shooting. I have repeatedly Initialized “FUJIFILM XApp”, re-paired the camera, reset wireless settings, and confirmed the camera is not in airplane mode, with both devices placed next to each other. None of these steps resolved the issue. Also, I am unable to update the camera firmware, as the process always fails with a “connection failed” message. I need clarification on whether this is a known firmware or compatibility issue and what the actual solution is.
    • Last day of autumn 2025. Autumn is gradual. Summer field crops slowly ripening. Cool, longer nights turn into morning fogs. Color (colour) touches here and there taking the place of flowers now resting until Spring. Then, after that slow introduction, Fall is everywhere. Winter is brash, Winter is not at all subtle. Freezing cold days and colder nights. The Sun struggles to get above the horizon. Bare fields, iced over streams and woe (‘Woe!! I say!’) to trees or shrubs holding onto leaves.
        But there is sledding, skiing and hot chocolate for those that like those things 😀.
      Winter is coming.
    • For some reason, the EV dial setting does not correlate to the EV setting displayed in the viewfinder.  My XT2 used to have parity between settings such that when the dial was at "0", the viewfinder also showed "0".  Has anybody else noticed this?  I've tried a reset of the s/w but no luck.
