Hi everyone,
Been using the X100V for a while now and I can't figure out how to set up easy access to be able to switch on or off the flash. I know I can do it from the Q menu but that as not really quick or convenient. Anyone has any suggestions?
  • 8 months later...
 FUJI: Why can't you allow for a "SOUND & FLASH" to be assigned as Fn programmable button???
This would be a good solution.
Quite incredible that the flash cannot be turned on/off with just a push of a button... on a PREMIUM camera...
Edited by alejon
When checked this shows to be misleading information
