Hi. I just bought 50 mm, f2 lens in silver for my silver XT3.
When I opened the box I saw that the hood was black. The protective filter is black too. That was very disappointing. Because now the lens looks very ugly. If I knew I would have bought a black lens.
I have also an X100V silver and its hood and protective filter is silver. This is how it should be. How can Fujifilm make such huge design mistake?
Do you know if there are silver hoods for this lens?
I found this https://fujiaddict.com/2020/01/17/new-affordable-zonlai-square-hoods/ but it's not available for sale anywhere.
Thanks for any suggestions.
AFshoot.com has a silver one for the XF50/f2. It's a 'vented metal lens hood' so more similar to the metal lens hood for the XF35/f2 and the XF23/f2 rather than the original plastic one. Also it is a screw-on model with a filter thread instead of a bayonet. Nevertheless it fits well and the price is great (just EUR 11.50 or so).
    • I am very tired of Fuji as a whole... They automatically deny responsibility on issues, quote crazy high repair prices and timeframes and when I accepted a (refurbished" replacement 100-400 instead of a repair because to would be cheaper and faster it developed the exact problem a couple years later, My XT4 is absolutely unreliable because of the turn on turn off issue that has persisted through numerous attempts to fix it and my 10 to 24 would not focus at infinity and struggled to focus at all, and I went through two of them because of focus issues. My sigma is much better.
