Ok guys, I am going to submit a pretty strange question.
I usually shoot Leica m9 and now I have bought a used xt10 (for fun) that I use mostly in manual mode with a 18mm f2.
i know what I am asking is very complicated and unusual, but I would really like the possibility to customize some button so that when I push it the lens goes instantly to a prescribed metric distance. Is there any Fuji camera that lets you do that?
  • 5 months later...
Hi Tommaso,
I am new to the Fuji world and not posting much here. I am also a Leica user and I setup my xt-30 with the 14mm in manual focus mode, like the Leica and using zone focus.
Otherwise, Ricoh GR proposes snap mode to a certain distance. Great feature 🙂 I hope this helps
