Hi!
I tried the panorama functionality of the XT4 last weekend and i was quite disappointed.
1. the only really important thing about panoramas is that every picture is shot with the same settings. as you can see in the attached file, this doesn't happen and you get a striped picture that is completely useless.
2. even if the camera would handle the exposure correctly, the file is reduced to a bare minimum ... like 8 MB... i know that this process is a lot for the processor in the camera but the result is absolutely disappointing.
What i actually don't get, is why the panorama functionality gets a quick access if it's not worth to be implemented corrently.
Edited by luckyLenses
