I had this happen, and its the first quirk I've found on my new XPro-2.
Shooting some test images, and decided to pull card #1 and view on my PC.   All was well, everything very nice, blew me away with the colors and tonalities.
I put the card back in the camera, and shot a few more tests.  Went to look at them in the camera, it says "no card".
Pulled the card, replaced #2 into #1 slot.  Same thing.  Put #1 in #2 slot, same thing.  Should have been images on both cards.
Very nervous at this point, I pulled the battery from the XPro-2 and put it back in.  Everything worked fine.  Both cards read, all images accounted for.
Any thoughts on this?  I'm thinking maybe I should have double checked that: a) the camera was off before pulling the card, and b) I did an "eject" from Windows before pulling the card from the PC
Other than those basics... I'm clueless
