Where is X100V made?
By artAlexion · Posted
That’s what I am referring to. There is a menu setting under User Settings for Tele, Wide, or Off. I believe it is designed to help with vignetting and such -
Which camera and which lens? My X100VI just works with the TCL-X100II and doesn't need any settings changes.
Walking around with the telephoto conversion lens attached. I either turn the camera off between shooting or it times out. Either way, the camera needs to be turned on again and I need to go back into the settings and enable it again. Is there a way to make this setting persist until changed again? -
The same here, the update for X App on Oppo find X5 Pro didn't solve the issue.
Just updated on my Oppo Find X5 Pro and still the same problem. It's definitely a firmware issue on Fujifilm's part because it stopped working after updating to the latest firmware update. I've given up on Fujifilm and bought one of these SD card to USB C which I can just plug straight into my phone and transfer files. It's much faster than the garbage X app and doesn't lag at all. Au revoir X app. See you again never.
