Was compressed raw ever made available on the x-t1?
By garyfallon · Posted
Well I have seemed to found the solution. SetUp-Screen setup-EVF Brightness-Auto/Manual. It was set on auto. However, when I choose "manual" and tried to make an adjustment is said "check the finder." While this did not allow me make any adjustments the EVF was substantially brighter. Problem solved. I wish to thank all the help I gave to myself concerning this matter. 🙄 (Actually I just got lucky before someone pointed all this out.) -
I have just received a new to me xpro2. It is excellent cosmetic shape, however, using an older analog lens the EVF is quite dim compared to the OVF which is nicely lit. I mentioned the lens only for reference. Question: Is there a setting for brightening the EVF or is this a problem with the EVF? -
By jakabasej8 · Posted
To prevent accidental touchscreen mishaps, check your camera's settings—there's often an option to disable touch control during shooting or playback. That could save you from some future headaches. -
I'd definitely recommend a firmware update as a first step, and if that doesn't work, try a different memory card. -
By maximkrykovich · Posted
I faced the same problem today. I don't know what to do!? I live in Russia, there are no service centers.
