I've been having issues locating 'USB raw converter' in the connections menu of my X100f. The option just doesn't seem to be there. When connecting my camera through USB into my laptop, I get the error message 'the connected camera is set to an incorrect connection mode' in Fujifilm Studio.
Any ideas on how to locate the option in camera, to use the camera as a raw converter with Fujifilm Studio on my laptop.
When I go to the connections menu on my camera, I see the following options -
- Wireless settings
- PC Auto Save Setting
-Geotagging set-up
-Instax printer connection settings
