I don't know if you can change to that eyecup or not, but when I tried to get the regular cup off to clean it, I nearly pulled it to pieces. There is a trick that's not in the book of pulling up then out. After the mess I made, I took my T2 to a jewelry shop to a man who works on watches. He put it back on better than it had been out of the box. He charged me nothing as he was glad to have something different to work on.
A little knowledge is dangerous...
Of course it is removable ! It even fits the old eyecup! ( see this http://www.fuji-x-forum.com/topic/3935-fujifilm-long-eyecup-ec-xt-l-for-x-t1-on-x-t2/)
Even on the later model of the X-T1 (mine) the eyecup would not come out so easily ( the first ones did and everybody lost them)
As shown in this video, not mine, one removes  ( Jiggling a little if needed) the old one and puts the new one on, there is no need of any goldsmith and no particular problems, in doing it just gently but firmly jiggle it (or, as shown in the video, lift up slightly the bottom portion of the eyecup and slide it out)
No reason to feel offended because I wrote that there was no need to bring your camera to a professional of any type!
There was no reason to bring this to a goldsmith or a lab... or a watchmaker.
You can see in the video that there is hardly any special skill involved, can’t you?
I appreciate that you wanted to share your experience ...
but you also were conveying the impression that this was something which required special skills and it clearly doesn’t, hence the comment “ No need for any goldsmith” (or a watchmaker) this is something that if anything , anyone should be able to perform, as indeed and no doubt intended by Fuji!
Internet is of a great help but one can easily spread faulty “ information” and before you know the X-T2 has the reputation to have an eycup that cannot be changed or that it requires a tech to change.
Maybe I should have made it into the joke: " how many technicians does one need to change a X-T2 eyecup? None!"
You were probably just overzealous in acquiring the services (even for free) of a watchmaker.
Half of my eyecup was pulled out, with one of the holes torn.  It was so flappy that it blocked the viewfinder.  I had to physically pull the edge down for it to register that an eye was near so the image would appear.  As it was, the viewfinder was black.  To repair it, I would have had to take out the tiny screws, lift and position the holes and the tabs.  I was on a ship in Asia and had no tools with me.  I asked the manager of the jewelry boutique if he could fix it and he did.
Maybe I wasn't clear that my problem wasn't merely pop and flip.  I had a badly damaged eyepiece that was making me crazy.
    • I never knew the X70 existed! Looks interesting.
    • Equipment: Fujiflim X-M5 (firmware V 1.10). iPhone 15 pro (26.1) I am unable to properly connect my Fujifilm X-M5 to XApp on my iPhone 15 Pro. This setup previously worked without issues, but now the app only supports a basic remote shutter and no longer allows Get or Take mode, which are required for remote parameter control and shooting. I have repeatedly Initialized “FUJIFILM XApp”, re-paired the camera, reset wireless settings, and confirmed the camera is not in airplane mode, with both devices placed next to each other. None of these steps resolved the issue. Also, I am unable to update the camera firmware, as the process always fails with a “connection failed” message. I need clarification on whether this is a known firmware or compatibility issue and what the actual solution is.
    • Last day of autumn 2025. Autumn is gradual. Summer field crops slowly ripening. Cool, longer nights turn into morning fogs. Color (colour) touches here and there taking the place of flowers now resting until Spring. Then, after that slow introduction, Fall is everywhere. Winter is brash, Winter is not at all subtle. Freezing cold days and colder nights. The Sun struggles to get above the horizon. Bare fields, iced over streams and woe (‘Woe!! I say!’) to trees or shrubs holding onto leaves.
        But there is sledding, skiing and hot chocolate for those that like those things 😀.
      Winter is coming.
    • For some reason, the EV dial setting does not correlate to the EV setting displayed in the viewfinder.  My XT2 used to have parity between settings such that when the dial was at "0", the viewfinder also showed "0".  Has anybody else noticed this?  I've tried a reset of the s/w but no luck.
