Hi
I want to hold my X-T1 more comfortly and "grippy way".
There is L plate bracket that give more ... Grippy 🤸
I found these kinds and n eBay and AliExpress but no product with this grippy thing.
Can you please help me find it?
From RUBBBER
Not plastic.
Thank you
Edited by shaby
