Hi Folks, I have an X100 VI and I like to shoot using the AE bracketing a lot with the style of photography that I mostly do, no issues there. So I set the camera up to shoot 5 bracketed images, at 1 stop apart which it does perefectly. However, if I turn the camera off between shooting to conserve battery life when i go to shoot another sequence it has reverted to just 3 shots and a 1/3 of a stop difference. Everytime this happens and it's got to be a real pain now as I can't find out how to keep it at the 5 shots and 1 stop increments that I selected.  Can anyone shed any light on this for me please as it's the one thing that is spoiling my experience with this camera.  Many Thanks in advance.
Edited by Pete Rowbottom
