No, it's a digital camera. They're all complicated and fiddley - even the point-and-shoot type.
Sometimes, I get the feeling that in the film era the choices were much simpler, and the camera was - at least potentially - a tool designed to help the photographer realize his/her vision.
But in the modern era, it's as though the designers don't even actually take photographs themselves, but feel compelled to produce the device with the most menus, buttons, and choices - regardless of whether they are of practical application in assisting the photographer.
