I just got a Fuji X-T20 2 days ago and I have some problems
first of all my battery takes a full day to charge which is very odd
secondly every time i record 4K it says “write error” however I did insert a old memory card on it with only 17mb writing speed, it works fine with 1080 recording but the problem only occurs when I record 4K. So I ordered a sanDisk extreme pro 32Gb with a 90mb writing speed and it will arrive in 3 days.
so can the problem be due to the old memory card or should I just return the camera and get a refund?
Edited by Shehab Ahmed
The new memory card should fo the trick.
Are you charging the battery using the supplied charger or charging it when its in the camera using a Usb cable?  You should never charge the battery while its in the camera because the charging goes through the cameras circuit board. Any electrical surge during the charging could damage the board. Hope this helps
