I recently got an XT20 with the 18-55 kit lens. Today I was trying it out at home, when I found out that when I try to zoom quickly in or out in manual mode, I see a horizontal light appear for a fraction of a second on the EVF. I cannot see this happening on the LCD. This happens only in manual mode, and not auto. This does not happen when recording a video. I am using mechanical shutter. But I don't think this is a shutter issue as I see this white line for a second when zooming quickly. Also I don't see it when I see EVF auto brightness from Auto to manual. The firmware is updated. Also tried zooming outside, I don't see that issue.
The issue is as described here by another user:
    • It appears that Apple now (at last!) fully supports FujiFilm Lossless and Compressed RAF files. In the latest updates of MacOS Tahoe 26.2, iOS 26 and iPadOS 26 compressed files are supported in Finder/Files and the Photos app. Good news for those of us with Macs and iPads.
