Regarding your Magic Numbers Scale ( and thank you for that and the research!)
Can you tell me how this scale will look when using the Metabones N/F - X mount adapter that only has a scale to 7?
I have it mounted to a Tokina ATX 100-300 f4 lens on a X-T1. The lens has 10 stops from 4 to 32, with 1/2 stops? between 5.6+8, 8+11, 11+16, 16+22
If I figured it out correctly the scale would look like this:
Lens Stops: 4-5.6-(6.7)-8-(9.5)-11-(13)-16-(19)-22-32
F=4
2=5.6
2.5=8?
3=11?
3.5=16?
5=22?
7=32
Have I figured this correctly?
Looks like the Nikon-Fuij X Ultra SB doesn't provided built-in apertuer blades but allowing us to control the aperture from the lens itself?
Yes. Built-in-adapter aperture blades won't work like an aperture in-the-lens. They will cause severe vignetting. The only way to have normal aperture control is to use lens aperture blades.
