I am wondering, what is the annoying thump I hear after pressing the shutter button after reviewing a shot on the LCD. I have removed the lens, still does it, turned off the stabilization, still there. It is strong enough to shake the camera body. Does anyone know? Most annoying to say the least.
Gene
  • 4 months later...
Normal for Fuji cameras afaik. My XT-1 did this, as well as my XE-2 and now XH-1. It's bizarre but nothing to be concerned about. I assume (probably incorrectly :p) that it has to do with locking up the sensor or something while previewing images and videos already taken. *shrug*
Edited by eurotrash
