1. Supports “35mm Format Mode” when using GF Lens and H mount adapter
“35mm Format Mode” crops the center of the sensor 36.0mm x 24.0mm (30.5M) and records JPEG and RAW file.
2. Improved eye-sensor response
Reduced the time to switch between EVF and LCD when you select “eye-sensor” on the viewfinder display settings.
3. Supports simultaneous delete for RAW and JPEG files
When RAW / JPEG is selected in the card slot setting (for still image), RAW/JPEG image can be deleted simultaneously. By selecting “OFF”, only the RAW image will be deleted.
4. Supports EVF and LCD color adjustment
Color of EVF/LCD is adjustable from screen setting menu.
