I took a series of RAW night shots using X-T2, when doing the post processing using Star StaX the end result had an odd pattern.  I used Lightroom to do the initial process, saved as full-res jpegs, then ran them through the Star StaX app. The result looked great at first look then discovered this odd vortex looking pattern.  It seems to be in the same location in all of the star trail photos that I processed. I've done some research but don't seem to find much information.  The only thing that I have found was that it was caused by the lens correction done in Lightroom, however, in Lightroom with my X-T2 the lens correction says "built-in Lens profile applied" and there is no way to get rid of the lens profile.  Is this the cause?  Can anything be done to get around this problem?
