It's my first wedding with my Fuji. I'm a guest, so no pressure, but the bride asked me to film the ceremony and take some pictures afterwards.
I've got a bunch of lenses but I'm not sure which one to take, to serve both the video and photography needs. I'd love some good advice from experienced wedding shooters!
Cameras:
- X-T1
- X100T
Lenses:
- 14mm f/2.8
- 23mm f/1.4
- 35mm f/2
- 60mm f/2.4 macro
- 80mm f/2.8 macro
- 135mm f/2 (Samyang, manual focus)
- 18-135mm
Also, I love the Samyang and how good it is for portraits. I'd love to take it with me, but I'm concerned about using a MF lens during a wedding. Is it hard?
Thanks for the precious input! ;)
Konzy
None of them.
You're either a guest or the photographer. If you're a guest, go and have fun with or without whatever you like and tell the bride, you're not "the" photographer. If you're the only photographer, why are you asking here? You should be a paid pro and know what to do.
This is just putting a friendship at risk if there are any expectations from her side.
Edited by cug
Big question here is whether you're going to be taking mostly candid photos or if they are planning to pose for you at all. If it's mostly candid, then the 135mm is a no go in my mind unless you are supremely confident in your ability to manually focus with high speed and accuracy.
For me, I'd go with the 35mm and either the 60mm or 80mm. You've got the 23mm covered with the X100T as a more environmental shot focal length. The 35mm is a solid all around lens to document what is happening. Aside from that, pick one of the macro lenses just as an intermediate lens for portraits with a little more reach.
Along the lines of what cug said, I would avoid taking anything too large or conspicuous. If they have hired a photographer, you don't want to come across as being part of that person's team. It may sound nice having photos from a friend/guest in addition to the main photographer, but you don't want your presence to disrupt that person's rhythm or perception among the other guests. If the hired photographer is good, they will get plenty of shots that have a candid feeling in addition to the posed photos. In that situation, I would consider approaching the hired photographer early and letting him/her know that you're going to be taking a few photos as a guest and ask them to let you know if you are ever in the way because you don't want to interfere with their job.
Edited by Nero
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
