Sorry, the title should have said focus bracketing.  Has anyone figured out how this works?  I have tried using it and the focus point doesn't seem to move at all.  What do they increments mean?  How do you judge the number of images? There doesn't seem to be hardly any documentation that came with the firmware 3 upgrade.
Edited by pjsokal
