Hey guys,
Just spent some time with Francis (One of the FujiGuys). I should've taken a photo to prove that I really did try the camera but oh well. If you believe me, feel free to ask any questions. Here are some quick points I noticed:
- The new shutter button sucks, way too sensitive.
- Body feels amazing in hand, the deeper grip makes a huge difference
- Eterna film simulation is very sexy
- IBIS works amazing
- Auto focus is faster but not enough to be noticeable
- Mechanical shutter is MUCH quieter
Disclaimer: I am not an ambassador or an employee of Fujifilm
Edited by kangmlee
