Sunny skies for our hike, and once again shorts and tee shirt fit the weather. We went all the way round Trail 401 in the Nature Preserve, and even did a bit of off-trail scrambling.
The amazing rocks, boulders, trees, vistas, and stillness were expansive and inspiring, as always. What a treat!
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
