Hi,
I'm using the XE2s with two sets of lenses.
  • Either 14mm + 18-55mm for outdoor use.
  • Or 18mm f2 + 35mm f1.4 for indoor use.
Anyone use the same?
Indoors it's sometimes easier to just use the 18-55mm zoom with a nissin i40 flash rather than juggle with primes. The zoom + flash combo  foregoes the compact approach and feels like a dslr, but the combo works faster and is more flexible.
Two other issues I have with these sets is a) the zoom is rather big for such a small body and B) the 18mm f2 images result in kinda snapshots.
So, anyone have suggestions where to go from there? Mainly trying to simplify, not adding extra stuff.
I was thinking of trading the 18 for a 23 but 23/35 is rather close.
Or trade the 18/35 combo for 23 f2 + 50 f2.
Way I shoot
What is the Job? - What am I photographing
- Take required equipment
If it is an indoor event -
Can I use a Flash
Yes = Take a flash
I use the 35mm F/1.4 for 90% plus of the time, but i'm happy to zoom with feet.
If I don't know the location, I'd probably take the 18mm as well.
For what I can not do with the 18 or 35, the 60mm does a good job for everything none bird/wildlife, for that you're looking at 50-230, 55,200, or the 100-400 (or 50-140 with TC)
The issues you have with size, not a lot you can do when you start adding flashes, I'm not sure what you mean by snap shots, as surely that is down to composition not the lens?
