Fleecy clouds and a cool breeze accompanied our hike today in the Nature Preserve. The incredible trees, boulders, rock formations, and vistas were inspiring and uplifting, providing a welcome alternative to the political horrors of these times.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10,
