Anyone try renaming the leaked beta FW?
minivini
Just curious. After perusing the quite long, and often pedantic thread regarding FW4, has anyone tried simply renaming it (eg 3.5)? Seems like that would potentially allay any concerns about not being able to update to FW4.0 later, once the official drops, and if this leak turns out to be a beta. I'll be installing probably tomorrow evening, and plan to try this unless someone already has with bad results.
Please enlighten us.. how do you plan to change the firmware's version ID ?
Renaming won't make a difference. Version number will be embeded
A very basic description of what you'd need to do.
Hack encryption, be good with assembler language to decompile the app (not many good decompiler apps), find location of version data (sometimes easier said than done), make sure there are no links / references to the Version data that could screw other functions up that reference it, recompile it. Then, pray to god it doesn't screw your camera up.
Seriously, don't go there.... unless of course you are a top rate programmer (but I doubt you'd be asking this if that were true). The chances are you'll brick your camera... it's not worth the risk.
I don't think there is much reason to worry about whether you can upgrade or not. This is not like a Windows upgrade where files are being applied selectively. I bet you can copy Firmware V1.0 onto a SD card and the camera will downgrade to it. Haven't tried it though :-)
    • Is there a way to keep your menu selection on the last option you used? For example.  When I select MENU the cursor defaults to MY Menu.  I scroll up to IQ settings, make a change, and return to shooting. When I press the MENU button again the cursor is back to MY Menu.  I really want it to stay on the IQ setting I was last using (or any other Menu setting). It's a PITA to keep scrolling up and down, back to the previous setting.  (Note.  My Canon Menu retains the position of the last option I was using). Thanks in advance for any help.
    • Im not partal to any brad, just opted to try these based on apparent price / performance.  I'm always looking for best bang per buck, hence Fuji I guess - haha Reliabilty does not concern me, as I always shoot to two cards for pro work (and burst shooting is not a part of that). Made sense for me to get the cheapest / fastest CF cards for hobby shooting.     I just got a Sabrent Rocket V60 512GB cheep (as the back-up card).   As long as neither of these freeze the camera I hope its a cheep solution for my needs. (AB AV Pro SE 512Gb and Sabrent Rocket V60 512GB).  Half a gig of redunat storge for $200USD is something I can live with. (Especially considering I can bust the hell out of the Anglebird). Cheers, Tomek
    • Would using an external charger be of benefit to the batteries life? I appreace it can be faster, but I doin't mind pluging in the camera over USB to charge. Does charging via the camera do as good a job as lets say the fuji's own external charger? Does the camera stop charging once the battry is full and not over charge? I couldn't find these deatails in these forums or in the manual. Thank you!   Image below shot on X-T2 in a sunny studio.
