Hello, flew from São Paulo to Rio de Janeiro this past weekend and wanted to share some shots from the airplane flight there.  Most of these shots were taken from the airplane window with my X-E2 and the XF 35mm.
Hope you like it!  I'll post separate entries so you may tell me which ones you like best by liking the post!
Thank you.
First shot was one of the ones I liked best, not from the plane.  This is Copacabana beach. These birds flew by in a cool formation and I was glad to fit them in the compostition.
18879565181_2684919cfe_c.jpgCopacabana Beach by Marcelo Valente, on Flickr
    • More testing of lenses today.  Nikon 70-200 f/2.8 IF ED VR (same applies to VR II) - dreadful. Heavy vignette at all focal lengths and apertures. Obvioulsy fine in 35mm mode.  Nikon 70-200 f/4 - some vignetting at full frame (similar to 24mm f/1.8 and Sigma 105 f/2.8 so probably correctable or slight crop to 80-90MP). Perfect in 35mm mode.  If weight is an issue for you the kit 35-70 Fuji GFX lens is lightweight and better than you might expect but isn't a fast lens at f/4.5-5.6
