Hey guys,
Hopefully someone can help me out.
I just picked up a used X100t and I'm unable to get the camera to switch from EVF to OVF.
So far I've done the following:
Made sure macro mode is disabled
Reset both shooting and setup menus.
Recharged battery.
When I flip the selector, the camera has no response... no beeps or other indicators
Thanks
Todd
