Good morning,
Camera: Yashica FX-D Quartz (Non digital).
Lens: Yashica ML 50mm F1.19,
          Yashica ML Zoom 28-85mm F:3.5-4.5
Question: What adapter should I use to put these lenses on my X-T2.
Best regards and thank you in advance.
RT
one of these? I like K&F
https://www.amazon.com/Concept-Adapter-Yashica-Fujifilm-Mirrorless/dp/B00OONJWTE
