Hi, I took my NEW  Fuji X -T50 to take some rugby pictures for my local club.
I set the camera onto shutter priority and selected Auto1 ISO which had a min setting of  200 and a max of 12,800.  I t was a very bright and sunny day and I chose a shutter speed of 1000th sec
I was so busy following the action that I failed to notice that it was choosing the max setting of 12,800 - so all my pictures came out very grainy and most over exposed.
Now admittedly I haven't read through all of the user guide yet, but the Auto setting is supposed to chose the ISO for you, depending on the lighting conditions.
A further test at home show that the ISO setting did not change whatever the shutter speed, so what I have done wrong - many kind thanks
Edited by Don62
Hi, thanks for reply, currently it just shows the battery reading.
I think I may know what happened. Before the matched started I took a picture of the team and the camera selected ISO 500, at a shutter speed of 1000th on Auto1.
The next picture, of a jet flying over, which I took to check the autofocus, had the ISO of 12,800, as did all the subsequent pictures.
I think I may have gone back into the menu just to check the MAX ISO setting but forgot that I had to go into Auto1 first before choosing the MAX setting. If the match is delayed, the light can diminish pretty quickly.
I've tested the camera this morning and it's fine on Auto1, with it changing the ISO setting, rather than the aperture to changing shutter speeds
Having used my trusty Nikon D5600 for years, I simply got into a muddle on the new menu, and was careless.
I'm am going to read the user guide and give the camera a thorough shake down over the coming weeks.
Well, i had the same problem with Fuji XT50. The solution is: first you set one of the auto options of ISO the low, and the high iso. Let's  say: Low ISO in 125 or 200, high ISO 1600 for a sunny day. Or higher in a dark day: 6400. Then you must go to set up menu (Symbol a wrench) choose button dial setting and the you set LOCK. Then in LOCK choose / SELECTED FUNCTION and then  / SELECTED. After that yoy go below, you choose FUNCTION SELECTION to block unwanted activations. In your case, you block ISO SETTINGS. Then  when you press the Q button you will see the iso mode DEACTIVATED. By the way, this happens  because you use shutter speed priority mode and the camera detects incorrect (usually very low speed. The problem is that the camera doesn't return to the previews selection and remains in high iso settings. Good Luck! (Advice: NEVER de-activate the LCD screen for reviewing pictures!)
