Hi,
I wonder if anyone had the chance to try the WCL-X100 and TCL-X100 on the X70.
The mount is the same as the WCL-X70 so it's technically possible, although I guess the distortion will be quite an issue...
Any interesting feedback?
Cheers
Antoine
  • 4 months later...
I used the WCL-X100 on the X70 on a trip to New York earlier this year. It worked out pretty fine, but gave some vignetting. Cropping to 4:3 or 3:4 format made up for it.
The WCL-X70 will get you even a tad bit wider, without vignetting. It also cost a bit less new. So if you plan to use the wide converter mostly on a X70, I would go for the WCL-X70.
Edited by NorAndFey
