I have a Haoge LH-FJ35 that I use on both the XF 32/2 and XF 23/2. It has the bayonet mount around the lens front so does not occupy the filter threads. It does not vignette on the 23mm. So the bayonet must be the same on the two lenses, So the 23mm Fuji OEM hood should also fit the 35mm.
Edited by pw-pix
spelling
