Hi
Wondering if some of you know of a good, reliable USB charger for the NP-95 battery. Need one to charge NP-95s from a battery pack, for those times when access to power outlets is limited or unavailable.
(I use the X100S so I can't charge through the camera itself)
Thanks in advance
Th
Try this
Fit the CP-95 coupler in the camera battery compartment
Connect the USB to Dc plug to the CP-95 and then to the Powerbank
Note: The power bank must supply 5Volts 2A
http://www.ebay.com/itm/CP-95-DC-Coupler-for-Fuji-FujiFilm-F30-F31fd-X100-X-S1-Real-3D-W1-/271104851803
http://www.ebay.com.au/itm/5V-2A-USB-A-to-4mm-Barrel-Jack-Plug-Male-DC-Power-Charger-AC-Adapter-Cable-Lead-/400843519838
http://www.ebay.com.au/itm/Xiaomi-16000mAh-Portable-Mi-Power-Bank-USB-Battery-Charger-Dual-USB-Port-/251760288582
This gives you a longer life useable system approx 8x the normal battery life
The other option is
http://www.ebay.com.au/itm/USB-Battery-Charger-For-Fujifilm-NP-95-Finepix-3D-W1-X100-X100S-X-S1-/112320849134?hash=item1a26d824ee:g:tBoAAOSwLnBXVtas
Use the power bank to charge on the move
thanks
Edited by nvp155
