Just sharing some pics from a walkabout in Barcelona last year. I had the 14mm, 23mm 1.4 and Zeiss 50, but I ended up using the 14mm the most. Some of my favourites (straight from camera JPEGs)
Fuji X-T10 | XF14mm | 1/550s at f8 | ISO 800
Fuji X-T10 | XF14mm | 1/680s at f8 | ISO 400
Fuji X-T10 | XF14mm | 1/900s at f8 | ISO 200
Fuji X-T10 | XF14mm | 2s at f6.4 | ISO 400
Fuji X-T10 | XF14mm | 2s at f5 | ISO 1000
  • 1 year later...
