Hi, folks. I picked up some silica packets when I got my camera, because it can be humid where I live. I only have the XT5 and two Fujicrons. My question is: Where is a practical place to store my equipment where the silica will actually do some good?
**I’m strictly a hobbyist and don’t anticipate owning a large collection of lenses. I’d prefer to not need another piece of storage equipment. The whole thing right now — all three items — live in a small Wotancraft bag that I’m very happy with. Is there any point to just having the silica packs in the camera bag? I have been assuming that putting them into something porous such as the camera bag would basically be a waste. To be effective, do they need to be placed with the equipment in something air tight?
Thanks. Rob
